Door clearance distance hotspots
I would swear years ago you could make doors display hotspots say 2 inches from the frame, so that you could position them leaving 2 inches for the drywall corner return, but I can't find how to do that now. Anybody remembers how?
3 REPLIES 3
DGSketcher
Legend
Minimum space settings?
Erwin Edel
There is an option to oversize the opening on most doors/windows. It does the oversize in 3D too (you get a bigger hole around your door/window, meaning you see air). Maybe this has replaced the option you are looking for.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
sinceV6
Perhaps you need the tolerance settings?
