Door does not show in section
Please refer to attachment. I have a door that shows in 3D and in elevation but not in section. I can "see" it highlighted in green in section if I select it but cannot figure our how to get it to show properly. Selecting "Move to Front" does not effect it.
Just prior to it not showing in section, I had used the axe tool to split the thickened slab edge twice below the door so that I could change the slab edge piece left between the two splits to a slab edge profile that is appropriate for under a door (i.e., wood blocking etc.).
I sent a message about this issue previously but the image did not show. It showed in preview then and in viewing the message as sent. I have reloaded it (68kb) and hope it shows.
Thanks in advance for any assistance.
DGSketcher
Legend
Could be a duplicate which can cause these presentation issues. It might have been created by the splitting but I wouldn't have expected the slab to affect the wall.
David Maudlin
Michael:
To amplify DGSketcher's comment, select the door, delete and check the result. Two doors in the same location can cause this problem.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
