Door handle position on door
jkershaw
Using USA library and the door D2 24:
It has the option to add four unique handles: left inside, left outside, right inside, right outside.
It does NOT allow for a unique placement (height and position) for each handle. Any change to height or position affects all four handles. Is this a bug or as designed?
In our case, we have exit devices on one side, and ladder pulls on the other. We've created a custom ladder pull, and AC places it on the door based on the bottom of the pull. Thus, we want to position the pull at 10" and the exit device at ± 34".
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
0 REPLIES 0
