bobup
Door keys
Greetings, I've just downloaded v29 and door keys or tags are not showing up on my project. I've picked a type and labeled one door for now as usual, but none of my door keys are showing up. I've clicked the model view option box for doors as well.
Everything looks good on the door selection settings. Any thoughts?
6 Replies 6
Lee Hankins
Are you using monolithic or libpack libraries?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
bobup
Thank you. I may be using the monolith libraries. I was hoping that when migrating from v28 to v29 that it would be seamless. I've migrated from v11 each year to now v29. I've never had door marks not show up when migrating from one version to the next. I'm still stuck.
Lee Hankins
There was a complete shift in the Library structure and how it works in Archicad 28 so I would have expected you to have the same issue when migrating to 28. Can you share a screenshot of your Library Manager window?
Lee Hankins
macOS Tahoe (26.0)
Erwin Edel
Check your model view options. There were major changes / shifts in how things work especially with level of detail in 2D and 3D for doors and windows.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
bobup
Here is a screenshot of the Library Manager.
Expand the warnings section and see if any of the door marker objects are missing.
They could possibly be in the Master Template 21 or AMT Libraries that are not loaded.
Or as Erwin suggested, check your Model View Options.
