Door leaf different style on each side of door
Is it possible in Archicad 19 to have a different style door leaf on each side of the door?
I am wanting to show different grooves on each side of the door without having to manually draw these on.
Do you mean a different pattern on the inside and outside of the door leaf?
If so you could make a custom door leaf and that should allow you to do this.
You just have to model it as you want it from a slab with different grooves cut into each side.
If you mean a double door with each leaf being different I would doubt this is possible with most door objects.
