Door orientation on the floor plan?
zgeorgievg
I want to ask is it possible to show door orientation left/right on the floor plan (as a part of dimension marker may be)? I am using AC18.
Thanks.
AC25 int, Win10 64bit
I haven't found it in the options so i think you need to code it.
You can also use the custom text parameter to manually add it, if so i strongly suggest using favorites, it's so easy to overwrite things and there is no coherence check between text and object.
zgeorgievg
Thank you for the advice.
