heathldesign
Door threshold not visible
I have been battling this issue for years and i still don't understand what is what. sometimes i can get the door threshold to show in plan, but sometimes can't. i thought i had it figured out on the last job. if i set the structural display to "without finishes" the showed up. but in this model, nothing i do makes them visible. the documentation tells me nothing other than to turn thresholds on and set the parameters. what am i missing here?
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
12 Replies 12
Seems it is a scale or MVO setting.
Here is the MVO setting that seems to show the threshold as I would expect it.
heathldesign
Ah, that did the trick. thanks. i didn't know that existed. you're my hero.
Heath
If you leave the detail level set to 'scale sensitive' the frames should adjust automatically as you change the scale of your plan.
Glad you have it sorted now - happy to help.
