2025-07-16 03:40 PM
is there i way to create a door with double side window? in library i can only find with just 1 window max that can be divided horizontally and not vertically
2025-07-16
03:49 PM
2025-07-18
05:23 PM
You can split the sidelight into two parts (if that is what you are trying to achieve) but not have two sidelights side-by-side:
hope this helps
2025-07-19
08:20 AM
2025-07-19
12:43 PM
Hi RobiLMan,
You can put to or more doors and windows together.
Use the mounting options to connect them.
