Door with double side window
RobiLMan
is there i way to create a door with double side window? in library i can only find with just 1 window max that can be divided horizontally and not vertically
CosminF
You can split the sidelight into two parts (if that is what you are trying to achieve) but not have two sidelights side-by-side:
hope this helps
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
BrunoH
Hi RobiLMan,
You can put to or more doors and windows together.
Use the mounting options to connect them.
ArchiCad 3.43 to 28
MacOS Monterey
Setup info provided by author
