Door with raised sidelite windows?
rob2218
so....does AC17 have any? see attached.
I'm looking to have sidelights that can be "raised" vertically off the ground plain.
Does AC17 have any door objects with sidelights where you can independently raise the bottom of the sidelites to a desired height off the ground???
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
19 REPLIES 19
Erika Epstein
Rob,
from within 17 do a search of doors as shown in screen shot. This will give you the AC17 compatible version.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
rob2218
thanks Erika for your help......so we are almost there.
it appears that when you "raise" the sidelite sills on this particular model.....the "CASINGS" no longer are available.....hubboy.
Almost there though.
thanks,
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Kristian.....does this door you are showing in this pictorial......are the "casings" available for this door or they are also "blocked out"??
Kristian wrote:
Rob the door you are after is called Door with 2 Sidelights 17 (funnily enough)
The Shape options in the user interface is where you will find how to raise the sidelight sills.
Then the Opening type and angle gives you a double hung option windows!
Don't sweat it, your thousands of dollars software has you covered!
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erika Epstein
Download "Door with 2 Sidelights 17". This one retains casing.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
rob2218
thanks....ALL of you!
you've been most helpful.
Erika especially.
Erika, question: where did you find these "doors"? I mean...who makes them? why are they NOT part of AC if Graphisoft indeed is the maker of them?
why do we have to go hunting and pecking to find wonderful doors like these that do all sorts of amazing trim and sidelight gymnastics....as opposed to why aren't they part of Archicad's Library of doors functionality?
i>u
Edgewater, FL!
SOFTWARE VERSION:
This door is part of the standard Archicad library as far as I can see - at least it is with the AUS version.
The USA version may be different it seems.
The BIM portal contains objects from anyone who wants to upload them so they don't have to be just from Graphisoft.
I believe also that Graphisoft upload all the various international versions so that everyone has access to them but I am not 100% sure on that.
When I browse for doors I see a few specifically for "USA".
No, this option is already in AC17 and show up in both objects.
rob2218
NO...it is not.
there are some doors that "don't" have the option to move the sidelite sill up or down........check it out.
I looked high and low and couldn't find doors with sidelights that were adjustable.
Now.....I'm curious....when I do a search in the objects search menu....a bunch of doors populate that search. How can I tell "which" doors are coming from the AC17 OOTB library and ones that "others" have made?
i>u
Edgewater, FL!
SOFTWARE VERSION:
The objects with the green globe icon are the ones on the BIM Components portal.
The ones without the icon are yours in your loaded libraries - these will show first in your list with the BIM Components object listing after them.
Barry
