Learn more
Geof Gainer
Door without frame?
In AC19, I made a shower door--a frameless 3/8" thick glass door to put in a glass shower enclosure. It worked perfectly.
But in AC21, I get a "Not enough edges in generatrix...in the 2D script of file DoorFrame.gsm" and a report every time I open the door selection settings. This goes away by increasing the frame thickness to 1/16". But shower doors usually don't have frames. Any way to fix?
Thanks
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
3 Replies 3
Does it have to be done with the door tool?
Can you use a shower screen object?
Geof Gainer
Good thought. It seems quite limiting in its geometry though, and frameless isn't an option anyway.
I have my own custom shower and screen objects so I don't use the standard GS ones and have no idea what they can and can't do.
What about just a standard thin wall with a glass building material (surface).
