Doors & Windows not showing correctly
archigreen
ArchiCAD 20 needs an urgent PATCH
undefined
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
Version / build of AC (19 as in your profile? But your version of El Capitan is out of date there...), - all windows/doors? all wall types? etc.? The screenshot shows such a big error, something else must be going on or you'd see 100's of posts about the issue.
Save a module of the wall with the door in it, zip it, and post here for someone to look at... and/or contact tech support.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Katalin Borszeki
Hi, we looked at the file and yes, the middle segment is filled with the same gray color as the wall. The reason is that the Renovation Status of the door is "To be Demolished". Once you change the renovation status or the renovation filter itself, the visibility of the door will be as expected.
Let us know if this solved your problem, best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
