Double Egress Door
Forgive me if this a stupid question with an easy response, but . . .
How can I get a double door to have swings in opposite directions, i.e. a double egress door.
Thanks
2 Replies 2
There should be a double egress door under 'wood internal doors'.
Would this do?
Thank You,
I can make this work.
I am working on commercial construction with Hollow Metal wrap around frames. Is there an option for a metal door/frame, or is this the only way to achieve double egress?
