Double Slope Steel Frame settings
Johann_P
I'm working with the "Double Slope" steel frame.
Is there a way to show it with a horizontal top?
I'm considering using 2x Lean-to frames with a beam connecting them, but would prefer to have the steel frame as a single object if possible.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Podolsky
Ace
If you experience any serious problems with this library part element - you always can replace it with a beam - as it has a lot of new features there and let to model structural frames using just one element.
Podolsky
Ace
Yes. The beam solution is even better if you want to schedule/quantify individual parts of it.
