Dontknow
Duplicate objects
I've got two duplicate object in my library.
Does anyone have an idea of where this duplicate can be coming from?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
One of them is in your "Embedded" library and the other is in the "Archicad migratie bibliotheken NL' library.
You may find you have two "FM_types" in one library and a third in the other library (there are 2 duplicates and one original that is not counted as a duplicate).
This object hasn't actually been placed in your model - it is just duplicated in your loaded libraries.
Delete the one (or two) from your embedded library and the error should go away.
There should only be one in your migration library which is the one I would leave.
Barry
Dontknow
Oke, thnx for the info.
I found one FM_type object in the embeded library.
Removing it solved the problem.
It's all still a bit of a mystery to me these library things. Migrating libraries, embedded objects, duplicate objects.
ArchiCAD 25.
