‎2003-12-11 01:58 AM
‎2003-12-11 02:46 AM
‎2003-12-11 02:51 AM
‎2003-12-11 07:44 AM
jdrulon wrote:Two ways.
This probably has already been answered. If so can somone tell me how to find the answer. If not - Is there an easy way to change all library parts already in a project created in either AC 6.5 or 7 from 6.5 or 7.0 library parts to 8.1 library parts without having to change each library part individually.
‎2003-12-11 06:52 PM
‎2003-12-11 07:02 PM
jdrulon wrote:Nothing much; the Special menu is not documented as it contains comands that have to be used at your own risk.
Thank you for your help. I have tried to do what you said but cannot find the "Special Menu" after I open the file in 8.1 and alos cannot find Update library parts command. What am I doing wrong?
‎2003-12-11 07:35 PM
‎2003-12-11 07:59 PM
jdrulon wrote:Did you click on the thumbnail?
Unfortunately the window you pasted into your reply is too small for me to read.
‎2003-12-11 08:13 PM
‎2003-12-11 08:17 PM
jdrulon wrote:Welcome
I realized that you could click window and enlarge it. Thanks.
I have gotten to where you change the value but would like to be somewhat cautious based upon your warning. What is the risk here? Should I save an extra copy of this project file before proceeding or can I mess more than just this project file up?There is no risk to the project if you are going to use only the Update library parts command. However, some of the others may have adverse impact - I personally never had any troubles, and the first thing after installing a new version is to switch the Special menu on!
