Learn more
JGoode
Edit Object Text in 2D Plan View
Is it possible to edit text in plan using a 2D hotspot?
I've been able to get the text to display within a 2D Hotspot box but not able to adjust it.
Although I'm fairly certain it isn't possible, I thought it was worth asking if there is actually a way of working around it.
I tried using a bit of code with this functionality to get it to actually display the text in the box:
		hotspot2 0,	0, hsID, half_sz1, 1+128	!BASE
			hsID = hsID + 1
			hotspot2 -1,	0, hsID, half_sz1, 3	!REFERENCE
			hsID = hsID + 1
			hotspot2 half_sz1,	0, hsID, half_sz1, 2, sz1, `1:1 Symbol Width`
Thanks
ArchiCAD 27
Windows 10
3 Replies 3
Hi JGoode,
If i understand you correctly, you may find information here.
Do you mean a stretchy text box like you asked for here?
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=67671
Guru
So with this object, you are wanting to be able to adjust the bounding box of text that is editable in plan view without the need to open a dialogue?
Ling.
