JGoode
Edit Object Text in 2D Plan View
Hello,
Is it possible to edit text in plan using a 2D hotspot?
I've been able to get the text to display within a 2D Hotspot box but not able to adjust it.
Although I'm fairly certain it isn't possible, I thought it was worth asking if there is actually a way of working around it.
I tried using a bit of code with this functionality to get it to actually display the text in the box:
		hotspot2 0,	0, hsID, half_sz1, 1+128	!BASE
			hsID = hsID + 1
			hotspot2 -1,	0, hsID, half_sz1, 3	!REFERENCE
			hsID = hsID + 1
			hotspot2 half_sz1,	0, hsID, half_sz1, 2, sz1, `1:1 Symbol Width`
Thanks
ArchiCAD 27
Windows 10
3 Replies 3
Hi JGoode,
If i understand you correctly, you may find information here.
Do you mean a stretchy text box like you asked for here?
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=67671
Lingwisyer
Guru
So with this object, you are wanting to be able to adjust the bounding box of text that is editable in plan view without the need to open a dialogue?
Ling.
