Steve Jepson
Edit size of part
How do I change the size of the alarm siren part?
When I open the part the dimensions i
I want to change are not editable.
I want to use is for the vent on the back of a Heat-N-Glo gas fireplace.
They've LOCKed A & B in the parameter script. It's just as well, because the shapes are hard-coded; if you edited the height and width nothing would happen.
You would need to save a copy and put some MULs in the script to resize the model.
A cylinder object from the basic shapes would be easier, though not as detailed.
James Murray
Steve Jepson
Thanks James,
Thats what I needed to know. I deleted the lock on A and B and it still didn't work.
The cylinder object will do the job. I didn't think of that.
