Editable text after object is placed?
JGoode
I would guess not, but is it possible to make a 2D object that has the ability to have editable text after the object is placed down? Kind of like dynamic hotspots I suppose.
ArchiCAD 27
Windows 10
4 REPLIES 4
If You wish for the prompt for text then no...but still You can edit object parameters...
Piotr
You can add hotspots to move and rotate the text but as Piotr said you have to edit the text value in the parameters of the object.
vfrontiers
If you are only looking for one string of text, you can use the ELEMENT ID...
I've done that on a bunch of objects...
Whatever you type in the ID can be displayed in the object...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
I did not write about the ID field...(I used it as well) because it is not a good BIM solution especially if IFC export will take place afterwords and the object is not a plain text object but a BIM element.
Best Regards,
Piotr
