Editable text after object is placed?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-06-22 03:58 PM
2017-06-22
03:58 PM
ArchiCAD 23
Windows 10
Windows 10
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-06-22 05:21 PM
2017-06-22
05:21 PM
If You wish for the prompt for text then no...but still You can edit object parameters...
Piotr
Piotr
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-06-23 03:13 AM
2017-06-23
03:13 AM
You can add hotspots to move and rotate the text but as Piotr said you have to edit the text value in the parameters of the object.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-06-23 06:34 AM
2017-06-23
06:34 AM
If you are only looking for one string of text, you can use the ELEMENT ID...
I've done that on a bunch of objects...
Whatever you type in the ID can be displayed in the object...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Visual Frontiers
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-06-23 07:48 AM
2017-06-23
07:48 AM
I did not write about the ID field...(I used it as well) because it is not a good BIM solution especially if IFC export will take place afterwords and the object is not a plain text object but a BIM element.
Best Regards,
Piotr
Best Regards,
Piotr
