Editing lift shaft
Ok im back, a new project and at least 2 million questions, ill start with 1
Ok im trying to edit the floor to ceiling height of Elevator 2 (default furniture item in archicad 8.0) i can edit everything except its height.
The elevator rises a total of 5 stories, and i want each door to start on the floor slab which rises equal heights of 3600mm. The only solution i can find so far is to install 5 single story elevator shafts adjusting the height of the header which is variable and defaults at 300mm but thinking about it ill have footers of the lift where not needed hmm, any advice would be champion!! thanks guys
absolutely typical, you spend an hour or so looking for an answer, you give up and resort to architalk, you submit a question, go back to it, do something else then find the answer!!!!!!!!!!!!!!!1 sorry
