Element not to drop shadow.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-10-12
12:12 AM
2023-05-23
04:10 PM
Rubia Torres
2018-10-12
12:12 AM
Originally, I tried to make it a transparent object, but to represent fine, I need to turn transparency on on the elevation which is not an option because my windows become transparent too (not desirable). So, How can I have that 3D element to represent as lines only without casting shadow?
Thanks,
C.
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-12 03:02 AM
2018-10-12
03:02 AM
When I make a layer wire frame, then no elements in that layer will cast shadow (tested in version 22).
Do you need to see shadows at all in the elevation - you can turn them off in the elevation settings.
If the tent is an object and you are able to edit that object, I believe it can be scripted so that is does not cast shadows.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-12 03:02 AM
2018-10-12
03:02 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-12 01:10 PM
2018-10-12
01:10 PM
Thanks Barry, Don't know what I did wrong the first time but I did it again and it worked. Thanks
