Elevator Shaft Height
Sakha
How do I set a custom lift height on the lift shaft? I can't change it in general or the shaft settings.
1 REPLY 1
CosminF
In order to access the shaft sub-menu, you have to "enable" it from the dimension settings page:
Afterwards, regarding the heights, you can opt to edit them from the slab and overrun settings, the shaft will follow accordingly.
hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
Setup info provided by author
