2023-04-13
05:45 AM
2023-05-11
12:09 AM
Gordana Radonic
Hi everyone,
Is there a way to add/embed 2D plant symbols to a 3D Plant Object? The 3D object I am currently using in my drawings has 8 2D symbols and I would like to add a 9th one into it.
I want to do so because I have already completed my planting plan and would like to replace the 2D symbols with a different for the already placed 3D object.
2023-04-13 08:02 AM
Yes it's possible, you'll need to modify the 2d script of the object in the GDL editor. If you have some programming knowledge its pretty straightforward.
2024-07-19 07:26 PM
I would really need to do this because I have hundreds of plants from AutoCAD 2D drawing I need to replace with 3D objects. Could You please try to explain in detail how to do it, maybe even add a tutorial video if possible? Thanks!
2024-07-21 06:38 AM
The original poster wants to add additional 2D images to an already available 3D object.
You are asking for your 2D objects to be replaced with a 3D object.
You will need to manually swap them yourself for an appropriate 3D object that hopefully has the 2D symbol you also want (or are happy with).
