2019-07-16
06:00 PM
2023-05-24
12:26 PM
Rubia Torres
Solved! Go to Solution.
2019-08-06 03:03 AM
Eman wrote:
No not a sliding folding door.
There are single & double hinged doors but I cannot find 3 or 4 leafs hinged doors.
2019-08-06 04:56 PM
2019-08-07 03:29 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2019-08-07 03:45 AM
2019-08-07 04:28 PM
2019-08-08 03:33 AM
Eman wrote:I have not seen a door object that can do this, but I don't actually use the default GS library.
Hi Barry,
The doors are hinged on each other.
2019-08-14 05:27 PM
Barry wrote:Yes in the door library I can find only single and double doors.
If the problem is you don’t have a 4 leaf object, that is a whole other problem.
Eman wrote:So for me it is more important the front elevation than the plan view. But yes I will do as you said I will explode the plan view as well.
What I mean is because sometimes I insert a door and then in the front elevation I need to draw the door design exactly as it is in real. What I usually do is that I go in the door or window settings and remove everything and I just leave the glass, so like that in the elevation it appears as it is empty so I can draw the door as in real and at the same time the door symbol appears in the plan view. I'm asking this question so maybe I can insert an empty door instead of having to make settings as I just said.
