Erase the hotspot 2
Chadi SAROUFIM
What is the fastest way to erase all of the hotspot2 lines from a script?
Chadi Saroufim, Assoc. AIA
M. Arch & M. Urban Design, Partner
Idepconsult – Mounir Saroufim and Partners
ArchiCAD 23 INT
Windows 11
4 REPLIES 4
Hello,
Not exactly what you asked but you can make the line a comment easily;
Using "Find and replace" make hotspot2 -> !hotspot2
Regards, Juha
Chadi SAROUFIM
maybe I was not very clear, if I create a library part saved from the plan, I will have in the 2d script a lot of hotspot2 lines.
I want to erase all of these lines.
poly2_b{3} 22, 3, 0, 0,
0, 0, 1, 0, 0, 1,
0.1698174588468, 0.5822956857974, 1,
0.1947422376475, 0.5479896708845, 1,
0.1880526783752, 0.5431294215796, 900,
0, -90, 4001,
0.1929129276801, 0.5364398623073, 1,
0.1527755720467, 0.507278366478, 1,
0.1479153227418, 0.5139679257502, 900,
0, -90, 4001,
0.1412257634696, 0.5091076764453, 1,
0.1120642676402, 0.5492450320787, 1,
0.1187538269124, 0.5541052813836, 900,
0, -89.99999999998, 4001,
0.1138935776076, 0.5607948406559, 1,
0.115204844872, 0.5617475320891, 1,
0.132606691483, 0.5398704125797, 1,
0.1492480377269, 0.5543365141689, 900,
0, 87.50000000006, 4001,
0.1629744854648, 0.5370800043103, 1,
0, 87.50000000005, 4001,
0.1670868624529, 0.567297178982, 1,
0.1583573834262, 0.5804859831174, 1
hotspot2 0.1698174588468, 0.5822956857974
hotspot2 0.1947422376475, 0.5479896708845
hotspot2 0.1929129276801, 0.5364398623073
hotspot2 0.1527755720467, 0.507278366478
hotspot2 0.1412257634696, 0.5091076764453
hotspot2 0.1120642676402, 0.5492450320787
hotspot2 0.1138935776076, 0.5607948406559
hotspot2 0.115204844872, 0.5617475320891
hotspot2 0.132606691483, 0.5398704125797
hotspot2 0.1629744854648, 0.5370800043103
hotspot2 0.1670868624529, 0.567297178982
hotspot2 0.1583573834262, 0.5804859831174
ArchiCAD 23 INT
Windows 11
rocorona
If you only want to get rid of the hotspot in the object symbol, follow the Juha suggestion. The exclamation mark will deactivate the Hotspot command.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
David Maudlin
Chadi:
Since all the HotSpot2 commands are together, you could also select all of the HotSpot2 lines, then use the Comment command (under Edit Menu when working on GDL parts) to add the "!", which will disable these commands when the script is read. If you actually want them erased, then just select the lines and delete.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
