Error in Windows 2D symbols.
Borgo1971
I noticed an inconsistent representation of the 2D symbol of the windows, i.e. the opening mark which seems to be sized on the glass and not on the opening frame. This becomes particularly evident in the case of very wide frames.
since ArchiCAD 4 now 27 on
MacPro 7,1 12x3,6GHz 64GB ram, powered by macOS 13.6.7
MBP 16" 2019 i9 8x2,33GHz 16GB ram, powered by macOS 13.6.7
Jorge_Arreguin
yes you are right thats a coding mistake and since the window is from the program library is impossible access to code and modify it and save as, may be the solution us create a new one
Borgo1971
I hope that developers will patch this issue. It seems not a huge job, for people that works with GDL every day. Personally, even I developed many library objects in past (with Archicad 5 to about 16), I lost the feel with GDL.
