‎2023-04-25
10:17 AM
‎2023-05-10
11:16 AM
Gordana Radonic
I noticed an inconsistent representation of the 2D symbol of the windows, i.e. the opening mark which seems to be sized on the glass and not on the opening frame. This becomes particularly evident in the case of very wide frames.
‎2023-04-25 05:26 PM
yes you are right thats a coding mistake and since the window is from the program library is impossible access to code and modify it and save as, may be the solution us create a new one
‎2023-04-28 07:32 AM
I hope that developers will patch this issue. It seems not a huge job, for people that works with GDL every day. Personally, even I developed many library objects in past (with Archicad 5 to about 16), I lost the feel with GDL.
