Error
Hi there
i have a problem when i want to use windows or doors,when i want to see them in 3d i have this error FILE NOT FOUND AT LINE 440 SCRIPT OF FILE ACASEMENT-A.GSM ,Iwant to know how can I solve it
tnx
9 Replies 9
Probably the Object you are using has a reference to a file in its script but cannot find it.
Check the Report window (File\Info\Session Report).
If it is an image file (tiff, jpg etc.) then it is probably a texture file the object does not find. You need to load the library that contains the file or the file itself in the Library Manager.
If it is another file, for example a TXT file, then it is more problematic, but I think it will be an image file so let's check that first.
These are the whole things I copied from report window.
I also did what you said about the contact manager and reload the objects, but I still have the error
Fill not found
at line 440 in the 3D script of file Casement_a.gsm.
Fill not found
at line 532 in the 3D script of file Casement_a.gsm.
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 45 walls 22 objects 14 columns 11 ncBeams
0 slabs 0 meshes 12 pitch roofs
Start time : 12/13/2007 5:22:07 PM
End time : 12/13/2007 5:22:32 PM
Elapsed time : 25 seconds
Projection : Perspective
Eye position : 30.4919 -85.4218 13.3578
Direction : 0.0545914 0.997973 -0.0326982
Distance : 10.2611 Angle : 75
Start time : 12/13/2007 5:22:32 PM
Elapsed time : 0 seconds
Eye position : 29.4828 -103.04 13.6919
Start time : 12/13/2007 5:25:55 PM
End time : 12/13/2007 5:25:55 PM
Eye position : 19.9157 49.4456 8.81956
Direction : -0.338471 -0.939914 -0.0447029
Start time : 12/13/2007 5:26:53 PM
End time : 12/13/2007 5:26:53 PM
Eye position : 17.6404 29.7237 7.59699
Start time : 12/13/2007 5:27:28 PM
End time : 12/13/2007 5:27:28 PM
Document name :
Processed : 0 walls 2 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:28:21 PM
End time : 12/13/2007 5:28:21 PM
Eye position : 35.2236 77.1791 10.6195
Start time : 12/13/2007 5:28:24 PM
End time : 12/13/2007 5:28:24 PM
Eye position : 34.2627 60.6449 8.59198
Start time : 12/13/2007 5:28:25 PM
End time : 12/13/2007 5:28:25 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 1 walls 5 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:29:50 PM
End time : 12/13/2007 5:29:53 PM
Elapsed time : 3 seconds
Start time : 12/13/2007 5:29:53 PM
Eye position : 21.9229 21.0219 7.03874
Start time : 12/13/2007 5:30:01 PM
End time : 12/13/2007 5:30:01 PM
Eye position : 24.8986 27.666 7.82692
Start time : 12/13/2007 5:30:03 PM
End time : 12/13/2007 5:30:03 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:31:06 PM
End time : 12/13/2007 5:31:09 PM
Start time : 12/13/2007 5:31:09 PM
Eye position : 53.5908 83.2495 0.584174
Start time : 12/13/2007 5:31:15 PM
End time : 12/13/2007 5:31:15 PM
Eye position : 9.31093 47.305 36.6434
Direction : 0.275943 -0.709535 -0.648394
Start time : 12/13/2007 5:31:20 PM
End time : 12/13/2007 5:31:20 PM
Document name :
Processed : 0 walls 1 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:31:24 PM
End time : 12/13/2007 5:31:24 PM
Document name :
Document name :
Start time : 12/13/2007 5:31:25 PM
End time : 12/13/2007 5:31:25 PM
Document name :
Start time : 12/13/2007 5:31:26 PM
End time : 12/13/2007 5:31:26 PM
Document name :
Processed : 0 walls 0 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:31:27 PM
End time : 12/13/2007 5:31:27 PM
Document name :
Document name :
Start time : 12/13/2007 5:31:28 PM
End time : 12/13/2007 5:31:28 PM
Document name :
Start time : 12/13/2007 5:31:30 PM
End time : 12/13/2007 5:31:30 PM
Document name :
Start time : 12/13/2007 5:32:32 PM
End time : 12/13/2007 5:32:32 PM
Eye position : 13.7388 40.5567 28.4291
Start time : 12/13/2007 5:32:34 PM
End time : 12/13/2007 5:32:34 PM
Document name :
Start time : 12/13/2007 5:33:08 PM
End time : 12/13/2007 5:33:08 PM
Eye position : 28.0884 18.7108 45.4778
Direction : -0.0149018 -0.202596 -0.979149
Eye position : 26.6664 56.7721 20.4042
Direction : 0.0455043 -0.878681 -0.475237
Start time : 12/13/2007 5:33:20 PM
End time : 12/13/2007 5:33:20 PM
Document name :
Start time : 12/13/2007 5:33:22 PM
End time : 12/13/2007 5:33:22 PM
Document name :
Start time : 12/13/2007 5:33:27 PM
End time : 12/13/2007 5:33:27 PM
Eye position : 39.8571 26.1878 8.62146
Start time : 12/13/2007 5:33:30 PM
End time : 12/13/2007 5:33:30 PM
Eye position : 28.3427 61.1701 21.7845
Start time : 12/13/2007 5:33:33 PM
End time : 12/13/2007 5:33:33 PM
Eye position : 26.561 45.7301 17.2391
Start time : 12/13/2007 5:33:34 PM
End time : 12/13/2007 5:33:34 PM
Eye position : 14.9257 46.501 4.94863
Direction : 0.131976 -0.985719 -0.104595
Start time : 12/13/2007 5:33:41 PM
End time : 12/13/2007 5:33:41 PM
Eye position : 15.0973 36.9063 4.67546
Start time : 12/13/2007 5:33:42 PM
End time : 12/13/2007 5:33:42 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:34:03 PM
End time : 12/13/2007 5:34:10 PM
Elapsed time : 7 seconds
Start time : 12/13/2007 5:34:10 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 8 walls 5 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:34:19 PM
End time : 12/13/2007 5:34:22 PM
Start time : 12/13/2007 5:34:22 PM
Document name :
Start time : 12/13/2007 5:34:23 PM
End time : 12/13/2007 5:34:23 PM
Eye position : 15.2802 28.8883 4.61767
Start time : 12/13/2007 5:34:28 PM
End time : 12/13/2007 5:34:28 PM
Fill not found
Fill not found
Document name :
Processed : 1 walls 1 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:34:41 PM
End time : 12/13/2007 5:34:43 PM
Elapsed time : 2 seconds
Start time : 12/13/2007 5:34:43 PM
Eye position : 15.2228 31.2949 4.36133
Start time : 12/13/2007 5:34:49 PM
End time : 12/13/2007 5:34:49 PM
Eye position : 12.9338 21.9379 6.57675
Direction : 0.157136 -0.965974 -0.20543
Start time : 12/13/2007 5:35:11 PM
End time : 12/13/2007 5:35:11 PM
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:35:24 PM
End time : 12/13/2007 5:35:26 PM
Start time : 12/13/2007 5:35:26 PM
Document name :
Start time : 12/13/2007 5:35:27 PM
End time : 12/13/2007 5:35:27 PM
Eye position : 12.907 22.2891 6.57873
Start time : 12/13/2007 5:35:30 PM
End time : 12/13/2007 5:35:30 PM
Eye position : 11.6728 36.4548 10.6354
Start time : 12/13/2007 5:35:32 PM
End time : 12/13/2007 5:35:32 PM
Eye position : 21.1976 37.3676 14.6326
Direction : 0.0580836 -0.949012 -0.309842
Start time : 12/13/2007 5:35:42 PM
End time : 12/13/2007 5:35:42 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:35:58 PM
End time : 12/13/2007 5:36:02 PM
Elapsed time : 4 seconds
Start time : 12/13/2007 5:36:02 PM
Eye position : 19.7283 28.3545 11.5692
Start time : 12/13/2007 5:36:08 PM
End time : 12/13/2007 5:36:08 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 8 walls 6 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:36:10 PM
End time : 12/13/2007 5:36:17 PM
Start time : 12/13/2007 5:36:17 PM
Document name :
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 1 walls 2 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:36:31 PM
End time : 12/13/2007 5:36:33 PM
Start time : 12/13/2007 5:36:33 PM
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:36:45 PM
End time : 12/13/2007 5:36:47 PM
Start time : 12/13/2007 5:36:47 PM
Eye position : 19.7253 29.8653 12.4873
Start time : 12/13/2007 5:36:51 PM
End time : 12/13/2007 5:36:51 PM
Eye position : 19.1688 32.5142 13.7149
Start time : 12/13/2007 5:36:52 PM
End time : 12/13/2007 5:36:52 PM
Eye position : 32.3054 42.0305 9.5548
Direction : -0.132171 -0.988844 -0.0686911
Start time : 12/13/2007 5:37:00 PM
End time : 12/13/2007 5:37:00 PM
Eye position : 31.9548 36.4758 7.97475
Start time : 12/13/2007 5:37:02 PM
End time : 12/13/2007 5:37:02 PM
Fill not found
Fill not found
Document name :
Processed : 1 walls 0 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:37:11 PM
*** User Break ***
End time : 12/13/2007 5:37:13 PM
Start time : 12/13/2007 5:37:13 PM
*** User Break ***
Document name :
Processed : 0 walls 26 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:37:14 PM
End time : 12/13/2007 5:37:14 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 1 walls 6 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:37:23 PM
End time : 12/13/2007 5:37:27 PM
Start time : 12/13/2007 5:37:27 PM
Fill not found
Document name :
Start time : 12/13/2007 5:37:38 PM
*** User Break ***
End time : 12/13/2007 5:37:40 PM
Start time : 12/13/2007 5:37:40 PM
*** User Break ***
Document name :
Processed : 0 walls 27 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:37:43 PM
End time : 12/13/2007 5:37:43 PM
Eye position : 31.9231 40.2835 8.70995
Eye position : 31.7356 36.327 7.42417
Start time : 12/13/2007 5:37:44 PM
End time : 12/13/2007 5:37:44 PM
Eye position : 30.5552 32.9381 7.2227
Start time : 12/13/2007 5:37:51 PM
End time : 12/13/2007 5:37:51 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 8 walls 8 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:38:00 PM
End time : 12/13/2007 5:38:06 PM
Elapsed time : 6 seconds
Start time : 12/13/2007 5:38:06 PM
Document name :
Start time : 12/13/2007 5:38:07 PM
End time : 12/13/2007 5:38:07 PM
Eye position : 30.6313 30.8787 6.97476
Start time : 12/13/2007 5:38:18 PM
End time : 12/13/2007 5:38:18 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 1 walls 3 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:38:20 PM
End time : 12/13/2007 5:38:22 PM
Start time : 12/13/2007 5:38:22 PM
Eye position : 32.9312 47.058 10.0078
Start time : 12/13/2007 5:38:27 PM
End time : 12/13/2007 5:38:27 PM
Eye position : 39.7563 62.136 14.881
Start time : 12/13/2007 5:38:30 PM
*** User Break ***
End time : 12/13/2007 5:38:30 PM
Document name :
*** User Break ***
*** User Break ***
User break
at line 1 in the Master script of file W1 Casement 11.gsm.
User break
User break
User break
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Processed : 1 walls 27 objects 0 columns 0 ncBeams
Start time : 12/13/2007 5:38:50 PM
End time : 12/13/2007 5:38:55 PM
Elapsed time : 5 seconds
Eye position : 40.6014 44.4154 8.82234
Start time : 12/13/2007 5:38:55 PM
Eye position : 38.55 36.4826 6.24852
Start time : 12/13/2007 5:38:58 PM
End time : 12/13/2007 5:38:58 PM
Eye position : 29.3756 37.6791 6.67688
Start time : 12/13/2007 5:39:01 PM
End time : 12/13/2007 5:39:01 PM
Eye position : 29.4173 31.0159 5.79029
Start time : 12/13/2007 5:39:02 PM
End time : 12/13/2007 5:39:02 PM
Eye position : 29.3277 28.5735 5.04019
Start time : 12/13/2007 5:39:10 PM
End time : 12/13/2007 5:39:10 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:39:12 PM
End time : 12/13/2007 5:39:15 PM
Start time : 12/13/2007 5:39:15 PM
Eye position : 28.2759 50.8213 4.68642
Start time : 12/13/2007 5:39:21 PM
End time : 12/13/2007 5:39:21 PM
Eye position : 28.2821 52.8662 4.56829
Start time : 12/13/2007 5:39:24 PM
End time : 12/13/2007 5:39:24 PM
Eye position : 32.1363 40.7869 4.98098
Start time : 12/13/2007 5:39:25 PM
End time : 12/13/2007 5:39:25 PM
Eye position : 33.5748 45.4182 5.24766
Start time : 12/13/2007 5:39:58 PM
End time : 12/13/2007 5:39:58 PM
Eye position : 37.3408 42.767 4.2466
Start time : 12/13/2007 5:40:07 PM
End time : 12/13/2007 5:40:07 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:40:47 PM
End time : 12/13/2007 5:40:51 PM
Start time : 12/13/2007 5:40:51 PM
Eye position : 36.7595 30.3726 3.16957
Start time : 12/13/2007 5:40:56 PM
End time : 12/13/2007 5:40:56 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:41:17 PM
End time : 12/13/2007 5:41:20 PM
Start time : 12/13/2007 5:41:20 PM
Eye position : 35.9472 25.4234 2.43959
Start time : 12/13/2007 5:41:24 PM
End time : 12/13/2007 5:41:24 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Document name :
Start time : 12/13/2007 5:41:35 PM
End time : 12/13/2007 5:41:40 PM
Start time : 12/13/2007 5:41:40 PM
Document name :
Eye position : 36.9287 27.5805 1.74253
Start time : 12/13/2007 5:41:43 PM
End time : 12/13/2007 5:41:43 PM
Eye position : 38.6143 32.1063 1.10482
Start time : 12/13/2007 5:41:44 PM
End time : 12/13/2007 5:41:44 PM
Eye position : 38.2815 38.8268 4.02839
Direction : -0.050746 -0.984131 -0.170032
Start time : 12/13/2007 5:41:53 PM
End time : 12/13/2007 5:41:53 PM
Eye position : 36.4774 34.2528 4.71978
Start time : 12/13/2007 5:41:56 PM
End time : 12/13/2007 5:41:56 PM
Eye position : 35.1134 30.5383 5.16805
Start time : 12/13/2007 5:41:59 PM
End time : 12/13/2007 5:41:59 PM
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill not found
Fill
I would like you to put two image attachements on this forum:
1. The screen capture of the exact error message.
2. The screen capture you see when you open the File\Info\Session report Window.
Next steps after that.
I Copied all the texts in Report window in my previous post.
and here are the screen shots you asked.
I have to say this, that every time I face this error I have to click continue botton for several times, then it dissapears and I can continue my job.
Thnx for your care.
Nice long report
Actually, as I see, the report says: Fill not found, not File not found.
So the 3D Script of your object is missing a Fill Type.
Maybe you delete a Fill Type from your project in Options\Fill Types or in Attribute Manager, but your object still refers to it and tries to use it.
You should check all parameters of the object to see if any one of them is trying to use a Fill and it says 'missing' as the selected Fill type.
Also check the same among the setting in the Floor Plan and Section panel of the Dialog.
By the way, the reason the error message comes so many times and you have to click Continue is because there are many instance of this problematic object.
tnx for your kindness,i saw that file missing in parameter,but how can i solve it,i chang that but still ihave that problem
Then here is what you should do:
Copy a Wall that contains one of those problematic Windows to the Clipboard and paste it into an empty Project file. Check if the problem is stil there.
If yes, save it as PLA, zip it, and put it up here as an attachment. I will take a look.
Maybe prior to saving as PLA you can pruge all unused attributes in Attribute Manager, plus check file compression ON to make the file size smaller.
David Maudlin
masoud_s66:
See also:
Library Parts Not Working Properly
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
