2020-03-13 10:40 AM
Solved! Go to Solution.
2020-03-30 10:09 AM
Radim wrote:Hi Radim,
Hi Barry,
Thank you very much for your work.
The problem is:
In older versions of ArchiCAD I set the Layers Intersection Group to zero and though the override fills are the same, they will not blend and line will remain. ArchiCAD 23 have not exception for Level 0, for the Layers Intersection Group.
Thank you for the suggestions but i need a system solution. Maybe i return to ArchiCAD 22.
Screen zoom % is probably a hardware problem.
Thank you and have a nice day
Radim
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-03-14 12:11 AM
2020-03-17 11:27 AM
2020-03-22 09:00 PM
2020-03-23 02:15 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2020-03-23 02:23 AM
2020-03-24 12:02 AM
2020-03-24 02:18 AM
2020-03-24 03:18 AM
2020-03-24 11:19 PM
