Extra lines on door frame
sorry i have no idea how to start my own question so i'm hoping someone sees this please. i am just starting out with a colleagues archicad 19 as i have come from autocad. i have the extra lines protruding from some doors within the floor plan. Not all doors but some. any suggestions please on removing these?
Just go to the appropriate section of the forum and click on the 'New Topic' button.
I would say that it is your 'Reveal Depth' for the door frame.
If you want the frame flush with the front of the wall then use a zero offset.
Otherwise you can add a positive or negative figure to move the from behind or in front of the door placement side of the wall.
DGSketcher
Legend
If Barry's solution doesn't work, I have seen this happen with the "casings" settings. Check the dimensions and whether you want them displayed.
thankyou heaps it worked
