Extra lines on door frame
sorry i have no idea how to start my own question so i'm hoping someone sees this please. i am just starting out with a colleagues archicad 19 as i have come from autocad. i have the extra lines protruding from some doors within the floor plan. Not all doors but some. any suggestions please on removing these?
3 Replies 3
Just go to the appropriate section of the forum and click on the 'New Topic' button.
I would say that it is your 'Reveal Depth' for the door frame.
If you want the frame flush with the front of the wall then use a zero offset.
Otherwise you can add a positive or negative figure to move the from behind or in front of the door placement side of the wall.
DGSketcher
Legend
If Barry's solution doesn't work, I have seen this happen with the "casings" settings. Check the dimensions and whether you want them displayed.
thankyou heaps it worked
