Am I right in thinking that FPRISM_ (and therefore HPRISM_) have a limit to the angle of the hill?
I note that this parameter for the angle of the hill must be equal to 0 or less than 90, but when I use an angle above approx. 80 degrees the hill 'slope' does not become greater.
Thus, for example, if the FPRISM_ has a base 0.2M square; thickness 6.3M; hill height 5.4M;and the hill angle is set to 85 the resulting object is wrong!!
Here's the GDL script of the 3D object, where the angle is 88.
RESOL 16
FPRISM_ mat, mat, mat ,mat,
4, 6.3, 88,5.4,
0,0, 15,
0,.2,15,
.2,.2,15,
.2,0,15
Any insight would be appreciated.
I know I can achieve the result I want using either the RULED object or 4 CUTPLANEs, but I am puzzled by the behaviour of the FPRISM_ in the circumstances I have described.
