2024-10-05 11:30 AM - last edited on 2024-10-05 11:46 AM by Barry Kelly
I'm having problems with the tool to convert favorites, is there any tutorial?
Since the link in question is not directed!!!!
2024-11-26 12:33 PM
Hi @ryejuan ,
Just to be on the safe side I've attached the manual here too to show the recommended workflow.
Since you choose to rebuild your project you may find this video from Central Innovation useful:
https://www.youtube.com/live/gotlCq8uhss
Best regards,
Magdolna
2024-11-27 04:25 AM
@Magdolna Marosvari thanks for the link its really helpful. Just one question how come Graphisoft didn't gave users the same tool that CI have?
2025-03-25 08:43 PM
The change from the "monolithic" library to the "global" library, and especially the Favorite Converter Tool, is undoubtedly a wonderful solution to create problems that we did not have before.
Thursday
Hi everyone,
our company skipped an AC version and I am trying to convert our favorites from AC27 to AC29. However I encounter two error messages on the way and I was unable to resolve the problem despite trying for an hour now.
1) When exporting from our template an error message say ArchiCAD encountered an "internal error". Does not say anything specific. However the folder ends up containing the xmls, so I tried to continue.
2) I open a new generic template, import the converter addon and try to convert, it ends up with
"Error! Error: Output file is not writeable:
Build FAILED!"
(First line repeated 6 times)
I cannot make the folder path simpler than "C:\ac28_fav". I am running as administrator.
I read this forum through, followed the tutorial to the letter.
Tried both AC28 and AC29 versions for the process, no luck.
No ideas left.
Help would be appreciated.
Monday
UPDATE: With help from Szabolcs Mikó i managed to convert. Short summary:
- opened AC 28: new project with existing company (old) AC27 template
- exported Favorites to "C:\ac28_fav" folder
- closed AC
- opened AC 28: new project with generic AC 28 template (new, Graphisoft issue), new library structure included
- loaded Favorites converter 28.71 (for AC28)
- converted Favorites to "C:\ac28_fav_new" folder
- Imported new favorites to this file (as well as other old template attributes: lines, fills, layer structure, etc)
