Favorite Converter - "uses libpart(s) with no libpack pair, keeping original" warning
enz_mc
Hello!
I'm in the process of converting the favorites of our company template to be used in Archicad 28.
(We were using this template in Archicad 27.)
Upon conversion, I get these warnings for some of the favorites:
warning: "11-FFE-FLoose-TablePaperclip" uses libpart(s) with no libpack pair, keeping original:
warning: "TABLE-0080502-1-paperclip-table-round"
warning: "11-FFE-FLoose-TableSong" uses libpart(s) with no libpack pair, keeping original:
warning: "TABLE-0020601-1-song"
warning: "11-FFE-FLoose-WardrobeLow" uses libpart(s) with no libpack pair, keeping original:
warning: "TABLE-0251001-1-round"
warning: "11-FFE-San-SinkCabSingleDoor" uses libpart(s) with no libpack pair, keeping original:
warning: "Cabinet Base Single Door 24"
warning: "11-FFE-San-SinkKitchenCabDouble" uses libpart(s) with no libpack pair, keeping original:
warning: "Cabinet Base Double Door 24"
warning: "20-Opng-DR-Int-Pocket-900" uses libpart(s) with no libpack pair, keeping original:
warning: "Pocket Door 26"
I'm just wondering if having these kept as original will cause any issues down the road.
From my understanding, it is not recommended to use both the monolith and global library in the same project?
Is there anything I should do to make sure these objects are converted properly?
Thank you.
That means that for the 27 object used by the favourite, there is no equivalent in the new 28 global library.
If you are not going to be using the 27 library objects (you are correct, it is recommended not to mix 27 and 28 librries), then just delete those favourites and create new ones based on the 28 objects.
ryejuan
I also used the favorite converter but didn't seem to help me transition most of our company favorites end us manually converting and some deleting of those unused favorites, am still having some issues with looking for the missing favorites in the library manager though. I hope Graphisoft can do a quick delete or clear or locate... Took me like forever searching and reassigning and some of it is still missing... 😅
In the end what is your Objective?
ArchiCAD 9 onwards
Setup info provided by author
