Feet and inches entry in parameter script
The apostrophe wraps entries for VALUES in the parameter script. Is there a way to use, for example, 1'-6" in the VALUES part of the script?
Thanks. Doug
David Maudlin
Doug:
In the GDL Reference Guide > Strings (p20 AC20 version) says these characters can be used:
", ', ā€œ, ’, `, Ā“
so you should be able to find one that works in your instance.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
That's perfect David. I did dig through the 19 reference guide but didn't see any reference to this. Big thanks for the info!
Doug
