kkmac
Archicad 28 4100 Unattended Update for Intel Macs
Not working. I'm getting Exit 8 error. Script looking at the wrong location when identifying app files. See 16:34:33 Mark.
This log is from /Users/Shared/Install.GS/
[16:34:31] Script stderr:
[16:34:31] Found ACs: 280AUSFULLv1 {/Applications/Graphisoft/Archicad 28 (Intel-based Mac)}
[16:34:31] installdir set from foundACs: /Applications/Graphisoft/Archicad 28 (Intel-based Mac)
[16:34:31] foundBuildNumber: 3001
[16:34:31] foundPackageNumber: 0
[16:34:31] To Update Found
[16:34:31] Variable set: searchArchicadVersion Archicad 28
[16:34:32] Tried to find file "com.bitrock.*" inside non-existent directory "~/Library/Saved Application State"
[16:34:32] caches (com.bitrock.*):
[16:34:32] Tried to find file "com.graphisoft.installer.*" inside non-existent directory "~/Library/Saved Application State"
[16:34:32] caches (com.graphisoft.installer.*):
[16:34:32] Checking Archicad 28 ...
[16:34:33] /Applications/GRAPHISOFT/Archicad 28 (Intel-based Mac)/Archicad 28.app/Archicad 28.app/Contents/MacOS/Archicad does not exist.
[16:34:33] Executing chmod u+rw,g+r-w,o+r-w "/tmp/installbuilder_installer_34903.log"
[16:34:34] Script exit code: 0
[16:34:34] Script output:
[16:34:34] Script stderr:
[16:34:34] Run: chmod, Parameter: u+rw,g+r-w,o+r-w "/tmp/installbuilder_installer_34903.log"
[16:34:34] Executing chown / "/tmp/installbuilder_installer_34903.log"
[16:34:35] Script exit code: 1
[16:34:35] Script output:
[16:34:35] Script stderr:
chown: /: illegal user name
[16:34:35] Error running chown / "/tmp/installbuilder_installer_34903.log": chown: /: illegal user name
[16:34:35] Run: chown, Parameter: / "/tmp/installbuilder_installer_34903.log"
[16:34:35] Executing chmod -R u+rw,g+rw,o+rw /Users/Shared/Install.GS
[16:34:35] Script exit code: 0
[16:34:35] Run: chmod, Parameter: -R u+rw,g+rw,o+rw /Users/Shared/Install.GS
[16:34:35] Executing chown -R / /Users/Shared/Install.GS
[16:34:36] Script exit code: 1
[16:34:36] Script output:
[16:34:36] Script stderr:
[16:34:36] Error running chown -R / /Users/Shared/Install.GS: chown: /: illegal user name
[16:34:36] Run: chown, Parameter: -R / /Users/Shared/Install.GS
[16:34:36] Exiting with code 8
Operating system used: Mac Intel-based 14 Sonoma
Since ARCHICAD 20
 macOS
0 Replies 0
