Takis
Fence Gates / Entrance gates
Hi, I have used normal double hinged door for the gates on the fence wall (see attachment).
The problem is that I can't see the door on ground floor plan because the fence wall height is below the story height.
I have already tried the following:
1. Change the Floor Plan cut Plane Settings - no lack
2. Clone the View on plan and change the Floor Plan cut Plane Settings to a lower value - this works but I am loosing the section fills of the walls and columns on the ground floor.
3. Save the door as an object - this solution is restricted for changes.
Any other ideas please?
(Archicad 21, Windows 10x64)
Takis
3 Replies 3
Ivan Myers
Hi there,
I just tried making a short door in a plan and I would suggest:
Select the gates > go to Floor plan and Section in the Settings Dialogue > go to Floor plan Display and change the setting to "Overhead All." Hope that helps
Ivan
Designer/ Drafter
ArchiCAD 26 on 27" Mac
Takis
Hi Ivan, unfortunately this didn't help.
I have found a solution just by accident. I did set the "Cut Plane height to current story" to "0" and now I can see the those doors on floor plan.
I have noticed that in Archicad 21 there is a little problem with refreshing the Plan View, so to be able to see the changes you need to go up or down a story first on View Map.
Takis
Guru
Have you tried setting the Floor Plan Display of the wall to Symbolic Cut?
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
