2006-05-10 11:32 PM
2006-05-11 08:17 AM
2006-05-11 02:15 PM
2006-05-11 03:16 PM
David wrote:Nice tip. Works like a charm...
Don:
For ArchiCAD Project files, go to Window>Open Project Preview. This preview is 128 x 128 pixels, so anything larger or smaller will be resized to fit when copied into this window.
I am using OSX.3.9, and if I select the file in the Finder, go to File<Get Info, select the small icon at the top of the dialog box, I can paste a custom icon image for the file here (do not select the image seen under "Preview").
HTH
2006-05-11 07:00 PM
2006-05-11 08:22 PM
2006-05-11 11:37 PM
Don wrote:Don:
David:
Thanks for the reply. To clarify, do I copy the detail itself, paste it into the project view window and then copy that image into the Finder Get Info window?
It works, but I found that I can copy the opened detail (or any part of it) and then paste that image directly into Get Info window and skip the Project View window altogether.
I never really knew what the Project View window was for really.
Don
2006-05-12 12:14 AM
