Find the perfect object, manage libraries, create custom objects
Finding out if a Parameter is Odd or Even?
I searched through the forum, but couldn't find an answer to this:
How do I find out if a user input (integer) parameter is odd or even in GDL script?
Basically I want to do something that says If num (user integer input) EVEN then GOSUB:A, IF num (user integer input) ODD then GOSUB:B.
I really appreciate your help, I am at a loss here.
Thanks.
1 REPLY 1
Another way of saying that an integer x is even is to say that x mod 2 = 0. So...
IF num MOD 2=0 THEN !num is even
    GOSUB A
ELSE
    GOSUB B
ENDIF
should do the trick.
