Fixed dimension, changing size
Is it possible that you have the ability to deside around wich hotspots will the dimensions of the object change?
eg. see the picture
If I have this frame that has 15 cm "offset", would it be possible that this value (15cm) stays the same whole the time, meaning that I want the fame to change its dimensions just around its inner points?
So if I have, weight/height (W/H) 150x150 cm, offset is 15cm
If I have 70x70 cm, offset stay the same - 15cm
12 Replies 12
You can make a parameter for the frame width. This will require writing (or editing) the GDL script.
This sound like a problem
Would this be maybe possible with ArchiForma, couse I read that you can model shapes and that its also an GLD tool?
Aussie John
It quite an easy GDL command
use poly2_
look it up in the reference guide
use the A and B values of the object plus a custom parameter. Good way to start to learn GDL.
Cheers John
[/size]
Do I use this GDL command after I modeled the frame with AC geometry, or I have to model it using scripting laguage to aply this GDL command?
You could modify the automatic script, but make sure the elements are at the (absolute) project origin before saving them. It is still probably easier to write from scratch.
Matthew, is there any egsample that would help me to understand this procedure and to aply it?
I was reading a little in AC manuals on GDL, but I didnt found even one egsample.
But what abouth ArchiForma?
Does it alow this kind of control over created objects?
See if you can find a copy of the GDL Cookbook by David Nicholson-Cole. I don't think David has updated in a while but all the basics (and then some) are there.
Mario wrote:
This one?
http://www.amazon.com/GDL-Cookbook-David-Nicholson-Cole/dp/0953521605/ref=sr_1_1/103-6419529-7512669...
Seem that out of stock, an it wont be even available
You could try David directly. His website is:
www.archicad-university.com/
There should be contact info there.
