Fixed dimension, changing size
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-04-28 06:20 PM
eg. see the picture
If I have this frame that has 15 cm "offset", would it be possible that this value (15cm) stays the same whole the time, meaning that I want the fame to change its dimensions just around its inner points?
So if I have, weight/height (W/H) 150x150 cm, offset is 15cm
If I have 70x70 cm, offset stay the same - 15cm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-29 02:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-29 10:19 AM
Would this be maybe possible with ArchiForma, couse I read that you can model shapes and that its also an GLD tool?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-29 01:05 PM
use poly2_
look it up in the reference guide
use the A and B values of the object plus a custom parameter. Good way to start to learn GDL.
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-29 07:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-29 10:39 PM
Mario wrote:You could modify the automatic script, but make sure the elements are at the (absolute) project origin before saving them. It is still probably easier to write from scratch.
Do I use this GDL command after I modeled the frame with AC geometry, or I have to model it using scripting laguage to aply this GDL command?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-30 12:00 AM
I was reading a little in AC manuals on GDL, but I didnt found even one egsample.
But what abouth ArchiForma?
Does it alow this kind of control over created objects?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-30 02:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-30 09:47 AM
Seem that out of stock, an it wont be even available
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-30 10:54 AM
Mario wrote:You could try David directly. His website is:
This one?
http://www.amazon.com/GDL-Cookbook-David-Nicholson-Cole/dp/0953521605/ref=sr_1_1/103-6419529-7512669...
www.archicad-university.com/
There should be contact info there.
