Floor Plan Window Missing From Tab Structure
William Gray
When I open my template, the floor plan window is no longer attached to a tab. If I open an elevation, section or other view, they open up correctly within the tabs. But if I select any floor plan view, a separate window opens (which has no link to a tab) and a header to the floor plan view which reads " ENTER PROJECT NAME>'VIEW NAME'>'FLOOR PLAN NAME' ". How can I reset floor plans so that they reside within the tab structure?
William Gray
Architect
Archicad 25 INT Build 4013
MacBook Pro Intel Core i7 2.9 GHz 16GB RAM
Mac OS 11.6
David Maudlin
William:
There is a command Dock Window to put it into the tabs. In the standard environment it is under the Window menu.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
William:
David
William Gray
Thank you so much - it's been frustrating me all day. I'm not sure how it happened either...
William Gray
Architect
Mac OS 11.6
