Force Object Description
We have just realised that the object description appears in BIMx. This allows us to describe the objects in the BIMx output.
I am pretty sure what I want can't be done, but can you code what appears in the description.
I would like the description to change as the parameters change
1 REPLY 1
Frank Beister
AFAIK you can't.
