Furniture "minimal space" - viewset control?
Does anyone know of a way to control the display of the 'minimal space' option associated with much of the furniture objects in the library using the viewsets?
I'd like to be able to switch this on and off in different Client presentation layouts, without resorting to putting duplicate objects on two different layers - one with min.space, one without.
Any ideas
Fanx!
The easiest thing is to save a set of Find & Select criteria to select all the appropriate elements and just change the parameter setting back and forth. Assuming that they all use the same (internal) variable name (which they SHOULD) this will work easily. There are other ways to accomplish this with display options or global variables, but you really don't want to go there.
