GDL: Call [User Defined]
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-12-12 02:46 AM
2019-12-12
02:46 AM
Is there a way to Call a user defined object? Turn it into Parameter?
Ling.
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 08:10 AM
2019-12-12
08:10 AM
I'm not clear on what you are trying to do here.
Normally when you call an object, you are passing parameter values to it.
It is possible to call an object in the parameter script, then if you have the same parameters in your calling object they can use all of the VALUEs from the called object.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 08:41 AM
2019-12-12
08:41 AM
Browse loaded objects, retrieve name of selected object and save it as a parameter value.
Curiosity. Was there not an object someone had made that could be used to scale and rotate another object along a chose axis? Wonder how that worked.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 09:24 AM
2019-12-12
09:24 AM
call as parameter is done in all "custom components" like custom door leaf or so.
we can use call 2 way: call "object_name".... or call object_name, so the first can be placed a text string parameter as argument of the call.
Piotr
Piotr
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 09:33 AM
2019-12-12
09:33 AM
Lingwisyer wrote:You mean the "Rotator" object that can be found in BIMcomponents?
It doesn't scale and you can't browse for the object name, you have to type it in (and if it is in the loaded library it will find it).
Custom components (i.e. door leaf, handle, etc) can be listed as a parameter and they are automatically found in the loaded library based on the subtype.
Maybe look a door object that calls a custom leaf.
I can't remember without investigating how they get the list of available custom components.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 09:49 AM
2019-12-12
09:49 AM
It is password protected unfortunately.
So you can't see the script.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 09:57 AM
2019-12-12
09:57 AM
Oh. Been a long time since I looked at it and I could not find it... seems like I remembered it's functionality wrong...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-12 11:45 AM
2019-12-12
11:45 AM
There once was an object made by Karl Ottenstein named Skewer, which used that functionality.
You can download it here:
http://www.opengdl.org/Default.aspx?tabid=2060&language=de-DE
Jochen Suehlo . AC12-28 . MAC OSX 14.4 . WIN11
