ā2010-09-16 10:19 PM
ā2010-09-18 01:24 PM
ac_wido_sill=0 parameters ac_wido_sill=ac_wido_sill...in your value or master script.
2.2. Door/Window objects ac_wido_sill - length This parameter provides full access to the sill depth of the opening object. The parameter can get a value list, it can be locked and hidden and its value can be set via the parameter script. Its current value will be assigned to the WIDO_SILL global variable for compatibility with older scripts. ac_wido_hide_options - integer Via this bitfield parameter you can disable options from the window/door settings dialog. ac_wido_hide_options = j1 + 2*j2. If j1 is set, the sill depth inputs on the default ArchiCAD settings dialog is hidden. If j2 is set, the reveal settings in the settings dialog are disabled.Hope this helps.
ā2010-09-22 02:13 AM
