2010-05-19 05:06 PM
2010-09-10 04:25 PM
2010-09-11 12:10 AM
!-- four string type parameters needed; !-- "valuelist_a", "valuelist_b", "valuelist_c", "search" !-- the code can be a master or value script dim value_a[], value_b[], value_c[] filename= "Table.txt" ch1=OPEN("TEXT",filename,"SEPARATOR='\t',MODE=RO,LIBRARY") !--counting the total number of rows do row= row+1 n=INPUT(ch1,row,1,string1) while n>-1 !--reading the first column for valuelist_a for k= 1 to row-1 n=INPUT(ch1,k,1,string1) value_aRegards, Juha= string1 next k !--reading the first column for valuelist_b if starts with the search string (valuelist_a) len= strlen(valuelist_a) for k= 1 to row-1 n=INPUT(ch1,k,1,string1) if strsub(string1, 1, len)= valuelist_a then r= r+1 value_b = string1 endif next k !--reading both columns for valuelist_c if contains the search string for k= 1 to row-1 n=INPUT(ch1,k,1,string1,string2) if strstr(string1+string2, search) then s= s+1 value_c = string1+ " - "+ string2 endif next k CLOSE (ch1) values "valuelist_a" value_a, custom values "valuelist_b" value_b values "valuelist_c" value_c
2010-09-11 12:14 AM
2010-09-13 06:30 PM
2010-09-13 08:25 PM
2010-09-13 09:32 PM
2010-09-13 11:45 PM
