2005-04-0801:19 PM - last edited on 2023-05-2412:11 PM by Rubia Torres
2005-04-0801:19 PM
After creating the GDL object (Door) and placing it, the door is getting placed but appears like a window in floor plan. The door swing is not showing in the floor plan. Where as the view of the GDL Object (Door) is perfect in elevation as well as in 3D view.
How did you create the door object? If it was created by saving from the 3D window, then you are seeing the top view of the door. To change this 2D view you will need to open the library part and change the 2D Symbol using the 2D drawing tools, or using the 2D Script if you want the 2D symbol to be parametric.
Hope this helps,
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
